bbbobbbo69
Hey all, I have a FS120 that i wanted to swap out the ignition coil of . It is one with bull horn handles & throttle/start/stop slider switch on right handle.When removing old coil the kill switch wire DID NOT go up the shaft to the slider switch but instead terminated under engine block.Upon opening up of slider switch I can find no evidence of any wires being there previously.But I know for a fact that the slider switch operated as it was meant to prior to removal of old coil.
So where would the kill switch wire end around the block , as I can't find any tab that the spade end would attach to? I'm stumped .
cheers
cheers
