Front wheels not lined up and seem bent
jrn497704
Went up a curb on an angle and now the front wheels are not lined up and seem bent ie; when one wheel is straight the other is angling left or right. I have a Craftsman YTZ 4000 24 HP. Its a bit of a struggle keeping it straight. Is this an easy fix?
Find out where its bent and either bend it back or replace the bent part.
Its the link rod that goes from one side to the other take it off, and straighten it in a vice, etc. I have bent mine before too if you look at it under the mower if its bent it will be bowed upwards.
