I have a Gravely Pro-Turn 260. I bought it used. One of the front tires goes flat over the course of a week. I have to refill it each time I use it. I was wondering if these can be repaired or should I just get a new tire? And, are they very hard to change out. Thanks.
I would get a bottle of green tire slime and fill it according to the directions on the bottle pertaining to the size of the tire. Probably 8 to 16 ounces would be in the correct range.
They can also be repaired with an inside patch, or adding a tube, but for slow leaks, I always go with the tire slime, and it is usually a permanent fix.
