filling front tires
mowerman05
Does anyone know how to fill front tires so they never go flat and what is the advantages or disadvantages of doing it.
Buy some Slime Tire Sealant. That should do the trick.
A week or so ago I had to fix my rear tire because it went flat over the winter and popped off the rim. After I resealed and inflated it I put some Slime in it. Haven't had a problem since.
That will rot your rim.... get it professionally foamed worked great for me 35 dollars a tire for my front and 40 ea for my rear the ride is a lot more bouncy but no flats :)
Quoted from the slime site:
I have heard Slime will ruin my rims, is that true?
Our Slime Sealant for tubeless tires is formulated with rust and corrosion inhibitors as well as a pH buffer making the product more alkaline. All of these ingredients work to protect the integrity of your rim. It is important to note there are factors which can allow damage to occur in spite of this. If you want to err on the side of caution, you can use Slime as a roadside repair. All you need is Slime and an air compressor! Slime can have an adverse effect on certain types of aluminum rims. Because alloys differ, it is difficult to predict how Slime will react with your rims specifically. Over the years, though, we have found that older rims are more susceptible to damage from Slime. Make sure that, if you have tubeless tires, you are using our tubeless formula. Our inner tube formula does not contain rust and corrosion inhibitors. Do not leave Slime inside your tires for more than 2 years. After that time, we cannot guarantee the integrity of your rims. If pre-existing damage is present, we do not recommend using Slime
Not always true. It only rots some aluminum rims. Also if your aluminum rim is powdercoated (if your mower is cool like that :P) then you shouldn't have a problem. Or you could use Armeseal.
I've never had a problem using Slime and I've been using that stuff for almost 5 years now.
Also from Slime Tire Repair site:
Will Slime Damage my wheel?
No, Slime Tire Sealant contains rust and corrosion inhibitors that protect against damage for 2 years. We recommend after 2 years you remove the sealant and replace it with new Slime sealant to ensure optimal rust and corrosion protection.
If you are worried about damage to your wheels, than do as I do and use a Smarttube. They are thicker rubber than any other tubes I have seen and have the added benefit of slime inside the tube. They have worked very well for me and I recommend them as they are more economical and give a better ride than the foam. No more bead leaks when using these tubes.
