Fibre washer on axle Model 20055
trooper1954
Hi all,
I need to replace the fiber washer in the photos....it was destroyed trying to get the pinion gear off the axle.
I have researched extensively on line with no success....no parts diagram of this model shows any washer at all for this model.
Can I just use a fiber washer that fits the bore of the axle....or is this a specific type of washer?
Auto Doc's
You can fabricate one out of fiber material or some nylon plastic such as a Gatorade jug cap. It is basically there to keep dirt and debris from getting to the shaft bushing. Make sure the thickness is the same.
When looking at the parts diagram for your mower it appears the diagram doesn't match the parts on your mower. It looks like the pinion gear in your picture has 2 flat sides and locks to the shaft, where as the pinion gear in the diagram has a 4 sided keyed hole set up for a slipper style key.
trooper1954
ILENGINE.....pinion gear does indeed have two flat sides....this washer simply prevents dirt getting into the shaft bushing.
Auto Doc....great idea, thanks
As IL says double check your model number. 20055 is a cast deck, while your pictures show a steel deck.
trooper1954
Sorry Rivets....working on two mowers at once here and gave the wrong model and serial numbers.....old age sucks!!!! :)
the washer is from a Model 20374 serial # 405360514...the washer still does not show on parts diagrams for this mower.....what would happen if I didn't replace it??
Thanks
Toro part number is 110-7191, which is what you are looking for.
trooper1954
Thanks Rivets....can you tell me where you found that part number.....here's a screen shot of my attempt to find it on the Toro website.
They maybe calling it a thrust washer item 15 on this diagram
Here it is on the Toro parts website item 15
