I've been looking for a replacement engine for my Toro Zmaster. The repair shop said the FH580v-AS03 was being replaced by a FH580V=ES21. However, one of the online supply houses just told me that all FH series Kawasaki engines have been discontinued and that I may have trouble in the future getting support or replacement parts. He recommended a Honda replacement engine which is about 25% more expensive.
Is it worth it to spend the extra $400-$500?
My Kawasaki seemed to run hot (it melted the throttle cable sheaths) and I'm now told that is a common thing in these Kawasaki engines. In your experience is this true of false?
Since these are fairly interchangeable, which one would you recommend to replace it with and why?
