B B.oles48 Member Joined Jan 6, 2012 Messages 12 Mar 25, 2012 #1 I have a 97 Ferris walkbehind 48" and the motor runs great the blades run good. The problem I have is the hydraulic pumps when the speed lever is at the fastest setting the wheels turn very slow I'm just lost any help would be appreciated. Thank you
K KennyV Lawn Pro Joined May 5, 2010 Messages 5,447 Mar 26, 2012 #2 WELCOME to LMF... First place to check is the drive belt, it could be loose, or just worn out.... :smile:KennyV
E esanger22 Forum Newbie Joined Jun 14, 2013 Messages 3 Jun 14, 2013 #3 KennyV said: WELCOME to LMF... First place to check is the drive belt, it could be loose, or just worn out.... :smile:KennyV Click to expand... My fault for not mentioning that I did already check that. Thanks KennyV! Any other ideas?
