Fall powerraking
Derek
This is my first post, Is powerraking in the fall a good idea? I mow lawns for a couple of friends as well as my own. One of the lawns is on the North side of the house and has lots of moss. I started mowing this one in early summer so was a little late for spring power rake
Hello & Welcome to LMF...
Power raking or dethatching is good if you have a very tight thick grass...
also handy prior to over seeding in the spring or fall.
Moss is a problem that will be there unless you can increase the sunlight, sometimes hard or imposable to do.... :smile:KennyV
