Engine F Series engine rebuild
The PTO shaft should slide easily out of the gear. If stuck it may be burred or stuck from old oil or dirt build up. You may have to wrap a piece of leather around the splines and then use a mini vise grip pliers using the leather to protect the splines and pull or pry carefully the shaft from the gear. Being careful not to harm the thin housing.
i need a way to take off this one annoying bolt at the bottom of the mower do i need to take of the blade mounting plate and fo so how do i without damage
