Exmark 2blade 48" cut- Exmark brand motor (24hp)
500 hours? Have the valves been adjusted? Initial adjustment should have been done at 300 hours.
Thats!!! What me and my small engine pal discussed... i assume dealer did it during troubleshooting but the report i just got emailed doesnt reflect such....isnt valve lash on these motors 10 minutes tops?
i thought there was may be some seconday failsafe system shutdown circuit...
Doubtful.
I researched this last year. My mower has a Kohler Confidant EFI engine, which is commercial. I've had problems with it, so I've looked through the service manual quite a bit. I found that it has the option of an oil pressure switch, but MTD in their infinite wisdom, decided not to opt for this $5 part on an engine for a commercial mower. I also found that my engine harness had the connector for the OP switch, so I added the switch. I was hoping that this would kill the engine in the event of loss of oil pressure. According to Grok, that's not the case. Such a feature is found only on engines that run unattended, like generators or water pumps. On mower engines, this switch will only prevent it from starting if there's no oil pressure. I guess that's something. I can also wire up the OP switch to a warning light, which I may do. I also found out that the EFI system on my engine can put the engine in a "limp home" mode if it overheats. This mode results in a big drop in power, and black smoke belching from the exhaust, I think due to the EFI system dumping fuel into the cylinders to cool them. Is this engine fuel injected? If so, Loncin may use a different method to protect the engine. If it's a carb'ed engine, then I seriously doubt that it has any such protection system.
Doubtful.
Carb and i agree mpt likely
I was more hoping some 1 would chime in woth first handle knowledge...
The blown motor, head gasket, timing
Dont add up to runs gr8 till hot then shuts down only whilenunder pto load
Instead of turning the engine from the PTO end, remove the engine shroud and turn it from the top. This will give you the opportunity to clean the engine cooling fins.
No but no noises n runs amazing
No but runs gr8 till hot under pto load usually 1.5 to 2 hrs the bluh
Shut down. Restarts a minute later and shutdowns get more frequent from there. Does that sound like bad valve timing
If you can adjust both sets of valves in 10 minutes, you should start your own shop. Labor book times allows 45 minutes per cylinder.
T.y for this info. ..
Sorry if i was posting mis-information, it was more so a question to the proper technicians based on conversations with some local shade tree guys. I wasnt claiming any record book claims, hell im on here trying to find an approach to resolving this "shut down when hot, otherwise runs flawless" issue.
Mower has ran great til 390 hours.suddenly instantly shuts down when mowing. It took about 1 or 2 hours of use before it started having this issue. I took to dealer and got run around for weeks couldnt recreate issue. I replaced coils/plugs/fuel pump fuel filter..... same problem :/
Called exmark area manager who said goto a different dealer half hour from your home and they will resolve this.
They did! Within 2 days they replaced pto switch, mowing side wire harness,(not engine side harness) and the pto clutch. I had no trouble since then and 150 more hours and one hot day after about 1.5acre mowed it shut down while active mowing.
I started cheap... coils,plugs,fuel pump,fuel filter, same trouble...
My question to yall is, would one of the 3 parts replaced by dealer be your likely culprit? I am out of warranty and will have to handle this myself :/ would like to save as much $$ as possible not throw too many more parts at this thing... any help appreciated
I read your whole thread. If the stop is sudden, I think it is one of your safety switches: seat, parking brake, pto. I would start with the seat switch.
Just throwing it out there, are you sure you don't have a safety switch issue? Seat switch, etc??
