Eratic RPM
suemikehome
Engine on aAgri-Fab tow mower (finish bushhog). Engine has new carb., fuel lines, filter, and fuel shut off. With throttle plate in open position RPM is about 800-1000RPM and when it feels like it the RPM,s will rise to 2000-2500 RPM and mower works great for a few minutes then the cycle repeats again. Thought about valve adj. but engine starts excellant.
Not much hair left
Briggs & Stratton
14.5 HP IC
Model 280H07
Type 0130E1
Code 061206ZA
Thanks,
Mike
Remove the valve cover and the spark plug, and turn the engine over by hand while watching the valves open and close. make sure both valves are opening the same distance. I have seen the intake lobe of the cam wear down to almost round and the engine would only run about half throttle.
Not much hair left
Briggs & Stratton
14.5 HP IC
Model 280H07
Type 0130E1
Code 061206ZA
Thanks,
Mike
adjust the valves first, but as said before look at the top end while rotating the engine.
