I replaced the Briggs engine on a poulan push mower, with the 799983 Short block,original model # was 122t02-1207-B1.
I can keep it running by manually holding the throttle open then once I let go it dies. I made sure the governor rod was adjusted right (according to a Taryl video) main jet is clear, and carb was working when swapped over.
