engine swap
tonymsanchez
I have a Tecumseh 13.5 hp., engine.I want to swap out engines .What is compatible, for an engine swap out. I heard bolt pattern and shaft size is important.
Buttanic
I have a rear engine rider with a worn out B&S. I also have an 18HP Kohler take off from a Toro front engine tractor. It look like it would be a tight fit but until I get the B&S off I can't be sure. Anyone have any thoughts.
Scrubcadet10
Moderator
Staff member
Start your own thread. This will only confuse others attempting to answer the OP
tom3
That 13.5hp motor a vertical or horizontal shaft?
Bkupmstr
Pay attention to the exhaust also
Swapped mine from an 8 to a 15 and th exhaust was the only issue
