Hey all, have a 10hp Tecumseh HM100 engine off a John Deere Snowblower that's giving me some trouble. As winter is coming and Lake Erie is giving me that leery look, I did my usual maintenance on the snowblower. Checked belts, changed spark plug, replaced oil, added fresh gas, and even removed and cleaned the carb. Didn't find any junk in the carb, which was promising. Got her all back together, and did the carb adjustment procedure in the manual. Dialed needle valve till finger tight, backed off 1 1/2 turn, choked, primed, fired right up. Turned needle in till she got rough, out till she got rough, split the difference. She sits fine at full throttle. Slowed her down, did the idle speed adjustment needle on the carb (same procedure).
Throttle back up to full and now that she's nice and warm drop the drive lever, engage the belt and the engine starts slowing and returning to full throttle. I can see the throttle linkage going in/out. Problem gets more pronounced when I hit the auger as well putting more load on the engine.
What would you guys do? Tweak the carb a little first? Or might this be a governor problem? Or perhaps some nefarious fuel or exhaust trouble?
