I just ran the Lt 2000 without the mower deck engaged the blades are still on but without even engaging the blades I noticed there's white smoke coming out of the air filter and there's some oil that I thought I solved spraying around on the oil filler tube side on top of the engine shroud so I think I better start there.
So I posed the question some AI application it might be from Google so the question I asked was could a blown head gasket create an illusion where you believe there's something wrong with the mower deck I asked something like that anyways here's the response from Google's AI engine:
No, a blown head gasket on a Briggs & Stratton engine does not directly cause physical damage to the mower deck. However, a blown head gasket can lead to various issues, including loss of power, excessive smoke, and oil leaks, which might indirectly make it seem like there is damage to the mower deck if these symptoms are mistaken for deck problems.
Quite often any AI response makes no sense for me anyways but this time I think it did pretty good.
Jim
I never thought of blown head gasket could cause problems with the mower deck butt
I would look into this before messing with the blades. No doubt blades need some love too.
What do you balance the blades with? Best and cheapest way to balance is using a precision food scale and a wooden block. I can balance a blade out to .01 of a gram.
To answer your question I have not used anything for the blades for this machine actually ever and there's really nothing wrong with them they cut they're not the sharpest but I was looking at that Oregon tool the one that looks like a cone and then I was looking at the one I think they make which month on a wall but I don't have anything but I did from my skiing background I took a 12-in mill bastard file and I just took a little bit of material off it's not very much on the older set of blades for the new blades I do not do anything + both sets of blades perform the same which I think is more indicative of what's going on with the engine so I was planning on ordering the I think it's the Oregon cheaper metal cone if you know what I mean.
Jim
