I have a push lawnmower that has a Quantum 5 hp Briggs & Stratton engine on it. I cannot keep the engine running. I have put carburetor cleaner in it and pulled the chord to confirm that the engine does run. I took the carburetor off the engine and used a compressor to blow out all of the orifices. I put the carburetor back on the engine and it will initially run and then quit. I have tried to mess with the choke to keep it running, but, it does not work.
Please Help
Please Help
