Repairs Engine Pulley On 22" Front Selfpropelled
MrSteve
Hey everyone! I posted a few days ago about the drive wheels froze on the mower. I pulled the assembly and took it apart and found nothing wrong with it. Is there a possibility of the engine pulley being froze? It does seem possible for that to be the issue. Isn't the pulley connected straight to the shaft or is there a gear mechanism that could be bad?
Steve
Not knowing exactly what you've got, you might just have to start from ground zero. Make sure everything that should rotate rotates, all the tensioners, belts, gears, etc. are in good shape.:smile:
