Here is one for the masses
Lazer Z, Triton 66, 30hp
When PTO switch is engaged, engine bogs
just for a second or so just after activating the switch. It doesn’t die, but seems close. Within about 1-1.5 seconds, it resumes normal rpm.
New air filter, fuel filter, gas is good, checked for a bad coil, no issues there either. Cylinder pressures check good and they are even at 171. Checked spindles and idler pulleys with belt off, smooth, no binding.
Could the PTO clutch be engaging too quickly causing the bog? Any thoughts what to look for?
