Encore 32" Mower
What does the mower have for an engine. By the picture it looks like a B&S. Look at the spindles, tires, front end and drive and find out if they can be greased or not. I believe they'll all be able to be greased. The thing about a walk behind that not real easy would be adjusting the cutting height, it can be a bit of a problem but if you're using just on your lawn once you get it adjusted you should be alright. It shouldn't be a bad mower for your purposes.
Thanks for the info! Not sure what kind of engine it has. I'm a little leery about buying the mower. It seems that the company was sold off and that their may not be parts available for it for some time.
Check it out if it is close to your location...
The one I have seen had a 14 Hp Kawasaki engine & a sulkiee hitch on it for a stand or sit on attachment... Seemed to be a fairly well built mower... :smile:KennyV
