Good evening. I am at a loss. I would like to begin by saying that automotive electrical is not my best subject. I try, but I end up with a mess usually, or I feel like everything works against me to create unique and unheard of issues. All that to say I need major help. I will try to cover everything I have done up until this point, because I may have messed something up along the way. Here we go:
2013 Ariens A22H46 lawn mower.
Lots of backfiring and battery kept draining. I replaced the coils and plugs, battery, major cleaning of the carb, changed oil. Battery was on the charger. Seemed to help, but then she started backfiring again and then wouldn't start. Bought a new battery and she ran great, then mower blades wouldn't engage and she wouldn't start anymore.
Replaced electric PTO switch and ignition switch and solenoid. Charged battery. Worked for a while until the PTO just quit. Read that it might be alternator so sure enough, not charging battery when checked with multimeter. Replaced stator and voltage regulator, checked inline 20 amp fuse (still good), still not charging battery. Don't know what else to do and don't know how to use a multimeter to its full potential.
To recap, these are the items that have been replaced with new parts: (and I bought them all from Amazon, but they seemed to be small businesses working with Amazon)
Ignition switch
PTO switch
solenoid
coils and plugs
stator
voltage regulator
checked fuse and it is good
still no charge at battery when engine is running. And battery is now showing 10.75 volts and will continuously drop voltage when it is running, no blades engaged or lights on.
I have bypassed the safety switch in the seat because it had finally given up the ghost. I bypassed it by removing the metal sleeve type thing in the harness under the seat. I saw a video on it but can't remember any more details about it.
Oh, and the ignition switch seems backwards. I used to have to turn it back one position to keep the blades engaged while backing up, that position has changed now. I no longer have to turn it back, and if I do, the blades will disengage when backing up. It's like the poles have reversed or something.
I think that is it. Again, I am not the best at automotive electrical and could really use some help. I want to learn because I know this hinders me and I won't let it beat me. Thanks for any advice.
Ignition switch
PTO switch
solenoid
coils and plugs
stator
voltage regulator
