Benhoff27
- May 6, 2022
- 5
I have an older cub zforce 44 zero turn. It's been a great mower up till now. Have an issue that appears to be a safety circuit issue, but after checking or replacing (or temporarily jumpering) the switches the issue is still there.
Mower will start fine. When brake is removed the engine cuts out. I had this issue at first mow this year, replaced one bad reverse cut out switch and the mower worked great. Next mowing it stalled mid mow and couldn't pull brake off at restart. Sounds like a seat switch but I've replaced it, bypassed it temporarily, and used multiple switches (which I know work) so I'm at a loss. The only thing that doesnt work well is if brake is on and I try to engage PTO, PTO turns on then engine dies. Could it be some electrical fault in the clutch causing the safety circuit to trip? Ran through all the safety circuit tests and everything else works as it should. Help!!
