Electric Clutch Question
KiltedOne
I have a 2005 Husqvarna YTH2448 (model 96013000700) that recently had a major belt break and tangle the wiring to the electric clutch, ripping it out completely. I just received my new clutch, but the wiring connector is totally different, though part number for the clutch is correct. I was informed to remove the connector from my old clutch and use it, but the mishap totally ruined the wiring to include the old connector. Can I just create my own connector using something like the molex connectors found on computer wiring and if so, is there a polarity for the clutch? Both wires coming from it are the same color, so not sure if polarity matters or if it is a just a matter of energizing the clutch.
Second question, when reinstalling the clutch onto the motor shaft, does it matter which hole the anti-rotation bracket fits in to orient the clutch?
There is no wiring polarity, and as long as it doesn't rotate you are good.
KiltedOne
Thank you for such a quick reply ILENGINE! Going out to put it on now as grass hasn't been mowed in close to a month due to rains, and then the belt/clutch issue. Needless to say, it is going to take several incremental passes to get it where it out to be. :laughing:
mechanic mark
Burnish new clutch by engaging PTO on for 10 seconds, off for 20 seconds, back on for 10 seconds, off for 20 seconds, do this several times.
