Electric Clucth
Taylor
Hello,
I have a craftsman 18.5 twin mower. My problen is the clucth will not engage. I check the harness at the clucth and it has 12.7 volt. The ohm reading at the clucth harness was 4.92. I thought it should be like 2.5 ohm or 3. I little confuse about the high ohm if it just as bad as a zero ohm reading. Can anyone give me some advice?
Thanks
?????...please give us year/model/serial numbers of your mower......thank you...:confused2:
ok..are you talking about a drive clutch or blade clutch?...give me the scenario that brought this on......im not aware that this one has electric clutch anything
