Snapperfreak
- Dec 13, 2011
- 676
I'm not sure if I was priming it too much, squeezing the throttle too much or what but when the 2400 died on me I tried the 2100 again just to see if luck was with me. It was. I set it to choke and primed it only 3 times. Got it to kinda half-fire on the first pull. So I set it to choke and tried again. Sounded more promising. Went to half choke and had to feather the throttle a bit but got it to start. And it's running perfect. Idle, normal use and wot. I mean it ran like brand new...like it always has when it's running. Trimmed first, then after mowing I came back to it about 30 minutes later. Started up on first pull with no choke. So next week when I go to use it I will be very careful how much priming and throttle I give it at start-up and will post what I find.
