echo srm 210
rodney12
have a echo srm 210, and got it run pretty good but when running the gas is coming out the vent from the gas tank?
If you are talking about the vent that is in the fuel cap, there is supposed to be a check valve in the cap to allow air in, but "not" allow fuel out.
The vent in echo is connected to a fuel line with a little white top. If gas is coming out seems like to much pressure in the tank are the other 2 lines connected right? One has a fuel filter on the end this one does not connect to the primer the other one connects to the primer.
If all is connected correct I would replace the little white vent and fuel filter while your at it replace the tank cap non of which cost more than a buck.
