Wow, thanks for all the responses! As a newb to this forum I was hoping for 1 or 2 responses, especially on what I thought was a pretty obscure issue. In regards to some of your answers, my mower does have a primer bulb, which unfortunately seems to have little effect during cold starts, although I'll give that more attention. I do know that a shot of starter fluid into the carb caused it to fire right up. Once it's warm it starts on the first or second pull. I just don't understand why the linkage to the butterfly valve currently causes it to be fully open when cold. The mower has no manual throttle or choke controls. Seems like it should either be a manual operation or controlled be a thermostat. Thanks again.
