have an e1170 mower that has a problem with the deck belt riding on back deck support causing belt to be eaten up. the spindles have been replaced, lift support/fuel tank bracket replaced, deck leveled, tire pressures within specs, deck pulleys replaced, new belt . understand the belt should ride on or be just barely touching the bracket but this one sets on or 1/8 below bracket, so looking for any reasons that the deck belt rides on top of bracket as low as it does. causing belt to be eaten up
thanks
AC
thanks
AC
