e-mail notifications
SeniorCitizen
Is there absolutely NO forum support from the administration?
Muhammad
Administrator
Staff member
Are you talking about subscribed threads? Please post more detail.
SeniorCitizen
Yes, and I go to subscribed threads but evidently don't fill the information out correctly. That's where I need direction.
7394
SeniorCitizen- Let me give this a shot. When you are going to make a post or start a thread, under that window you type in is an area in the green frame called Additional Options"
Scroll down to "Subscriptions" Make sure this is checked, then the window next to that check box will give you options to get replies. I always leave mine set on "Instantly, using email" ..
Hope this helps ya..
SeniorCitizen
Ok, I found that and thanks. I'm assuming this must be done for each thread I reply to. Is that correct?
7394
Once I set mine, I never had to touch it again.. So you should be good, but when you make a post you could check to see that the box is still checked..
And FYI: At times this forum doesn't seem to send email notices of a reply. But lately it has been sending them fine.
And if you want to add pictures, look above "Subscriptions" & click "Manage Attachments" & follow the prompts.
