I put the new gasket on and the head bolted in at 18.4 ft. lbs. I put a little grease on the engine side of the gasket. Now, I am still confused re setting the valves. On this Itek 18.5 hp engine...
Is the top valve the INTAKE and the bottom valve the EXHAUST? Looking fromt the front of the engine my carb is on the right side and the exhaust pipe on the left.
Also, in adjusting the valves. Can I adjust both when on TDC? I have read two methods...One is the TDC when both valves are closed....valve springs fully extended?
and the other method is when one valve is closed and the other open....now, my confusion:
when one valve spring is fully extended out...is that valve opened or closed?
THEN, the other valve spring...pushed in farther would be the opposite?
Thank you. I am hoping to do this tomorrow.
