marcwukits
- Apr 23, 2013
- 1
- 4
Last year I noticed a rather disturbing oil leak under my badboy 60"ZT just behind the left side (if sitting on it) tire. Roughly a half a quarts worth. I looked underneath and it was obvious that it came from a small black nipple with a yellow cap about the size (diameter) of my index finger. In my ametuer opinion it looks like some sort of pressure release valve. I checked the oil, it was obviously low. I topped it off, started it up and waited to see if it leaked. IT DID NOT!!! I drove it around the yard for a few minutes, again not a drop leaked out. So I cut grass for 10-15 minutes and checked it again, NOTHING! Proceeded to cut the entire yard (1.5 acre), parked the mower and checked the oil again. No leaks, oil level maintained just fine. Came out to the garage two days later and it had puked oil on the floor again!! I only had one more mow for the year so I did everything described above one more time with the exact same result. This mower only has 120 hrs on it and has been maintained very well. Any suggestions as to what the problem might be. Any help would be greatly appriciated.
thanks
Marc
thanks
Marc
