17hp twin cylinder liquid cooled Kawi on a JD LX279. Got it out to start the season and used it about 15 minutes and parked it and saw oil dumping from the bottom. Raised it up and removed the PTO and pulley and the bottom seal looked good but that's obviously where the oil came from.
I replaced the seal and ran it about 15 minutes again and parked it and it dumped the oil again. I figured I had just gotten sloppy when replacing the new seal. Raised it up and again I could tell the oil came from the seal but it looked good.
I got another seal. Removed the old one. Checked the shaft very carefully. No burrs, marks or rust, it was very clean. I carefully installed the new seal. Ran it for about 1 minute with the PTO and pulley off, no drips at all. Two days later I got the mower out and ran it again and about the 15 minute mark it started dumping the oil again.
There was an old thread here with someone who had the same exact issue but there was never any cause identified.
I'm using Rotella synthetic, I forget what weight. Mower runs good otherwise, no smoke, no knocking.
There is no oil dripping from the seal. It's not until the mower has been running about 15 minutes and then it dumps the oil, a good steady stream.
Does anyone have any idea what's going on here?
