Dual gas tank - bypass valve
martin1b
I have a Hustler fastrak with dual tanks. The tank switch valve is leaking and I'd prefer just to bypass so both tanks feed into the main fuel line so I don't have to switch.
Can I just bypass the switch/valve and put in a tee? Any issues doing it that way?
I would say, use a T fitting, but place a manual shutoff valve in each fuel tank line. Fuel expands and contracts with temperature change and this will eventually place too much stress on the carburetor float and needle.
The anti-backfire solenoid does not perfectly seal and prevent fuel from seeping by.
Even if this fuel injected, use line shut off valves.
would the vented gas caps resolve that?
My understanding is that most equipment in recent years has been using tank vapor emissions systems and the open-air vented gas caps are a thing of the past.
