Driveshaft on a Ford GT95 lawntractor
faye1612
The driveshaft came out on the motor end after the motor was removed on my Ford GT95 lawn tractor wirh a Kohler Magnum 20 motor. I disconnected the ends in order to get it back in. Do I need to match up more than just the bolts? Now it makes a noise when trying to start it. Do I need to match any markings on the flywheel? I also found info that said a key was needed. Any idea what the size is and is it on both ends of the driveshaft? Thanks!
As far as I know you could trying the install the drive in a Ford Pinto. No equipment info provided. We need make, model, and sometimes even the serial number; plus need the make, model, and spec number for the engine.
