Kennykenny
I have a Stihl BG55 blower. Every time that I fire it up to use the blower there is a gas or oil-like liquid that drips from the spark arrestor or from that area it seems. Any idea of what may be causing the dripping liquid?
What fuel/oil ratio are you running?
Does it "smoke" while running, as mentioned earlier it MIGHT be your fuel-mix, I am among those that strongly believe in using the 100:1 mix, You will find arguments here all year-long for and against this issue, all I can say is, if you decide to try the 100:1 mix, BE SURE !!! you measure correctly ! ( I mix 1.2 oz. of Opti-2 with 1 GALLON of gas ) I personally use OPTI-2 synthetic, have been for about 25-30 years now, NEVER an engine failure, ( I have a Maruyama BC241 brush-cutter, and a Shindaiwa LE20 stick-edger, both OVER 25 years old, still running, ( just have a hard time finding parts for those machines,) Have a 5 year old Stihl FS-90R been using OPTI-2 since day 1 ... It's YOUR call,
http://opti2-4.com/index.php?dispatch=categories.view&category_id=165
I get mine at the local Tru-Value Hardware store, ( my local mower shops just "PUSH" Stihl, and JD oil mixes ) I have a small dealer that has it but he's quite a distance to travel. ... View attachment 34885
I use Husqvarna 2-cycle oil mixed at 50:1 in all my equipment, the equipment I repair, and the equipment I sell. It's a very high quality synthetic oil, and it also has fuel stabilizer in it to keep your fuel from going bad. You can get it at Lowes, it's in a black bottle with a blue sticker.
Can you post a picture of the blower so I can see where it's dripping and what it looks like?
Thanks Primer. Here is the pic of the blower and the arrestor. I will add a pic of the drippage when I use it again and it happens.
