johnnyg5419
- Jul 26, 2017
- 12
I have a problem with my Dixie Chopper Iron Eagle. Hydro-Gear ZT-2800 on left side if you were sitting on seat, it goes forward faster than other side and has power. If you try to go in reverse it spins very slow and you can stop it from spinning with your hands.
I have taken control linkage off and turned the forward and reverse shaft with a wrench by hand to make sure linkage was not out of alinement. It just slowly started to do this as i noticed it would not turn to the left anymore. What could be causing this? Belts are tight.
