I found what some have said is the model # sticker, and it has 17101226. I can't find anything that says that's a model number. The sticker is on the frame by the right front wheel. It's a Kohler 25hp powered mower made in 2016. I can't find anything that says it's a model number. Any suggestions? I'll be able to check tomorrow
Can anyone point me to owner's manual? I want to see what maintenance needs to be done for the drive system. It's not my mower, but I use it twice a month to cut a 5 acre property, so I spend some time with this machine. The drive levers have been feeling funny, like there are dead spots. It's easy enough to work around by using the other side, but I'd like to clean it up. It doesn't do it all the time, it seems to come and go.
Should I be looking to change hydraulic fluid, flush air, or what?
