PTmowerMech
- Apr 16, 2018
- 405
- 3,100
Someone gave me an LX188. It's been sitting forever. Even the mower they bought to replace it is old. So this one must be ancient. None the less, if you look at a piece of plastic on this thing it breaks. I was seeing if it would fire off and pushed the throttle lever to the choke position, and it broke off in my hand. (and jabbed me in the process)
And what an over complicated mower this this is. A radiator? Come on, it's just a mower. It's got me thinking about taking it to the scrap yard.
But first, I wanna do some research on it. It's got a Kawasaki engine. FD501V-CS00 (FD501V061146)
Says it's got "full transistor ignition." What ever that means.
"Full warning system." Which tells me it's probably got too many sensors.
What I do know so far. It'll fire. But needs a battery and a new +battery connector. The trans neutral lever is in tact and the trans goes into neutral.
It's got two flats and almost every plastic piece is broken. No headlight harness.
There's little rust on it. Seems what little painted surfaces that are on this, got a good paint job. Including the deck.
So it's got some plus and minuses.
I just gotta check out prices for the hood. I think the plastic grill may be in good shape.
