deck belts breaking
bladerunner
mtd yardmachine lawn tracter keeps breaking belts. any general ideas on why, other than correct belt size or put on correctly. replaced a couple of times successfully in the past but now they dont last more than a few minutes then the whole deck will begin to shake violently then belt burns up. pullys appear to be lined up fine, not a lot of obvious play in any of the pullys but one is definately scored. thanks
cubby
I would look a little deeper at that scored pulley and all the pulley and or any shaft bearings, it sounds
like a bearing getting ready to seize.
Also welcome to LMF......cubby
reddragon
this isnt right at all......look at the belt guides when the deck is raised and lowered....make sure the belt is routed properly....if its flopping....its either a too long belt or a pulley is loose...get back after you take a look:thumbsup:..............go head and give us the model/serial numbers of the mower too:thumbsup:
bladerunner
its the belt that is called for , tight when engaged, no flop when moved through the diff heights, and pulleys have no play.mtd yardmachine 17 hp, 42" cut, model 13ak608g062.
Had a new Yard Machine in the shop a few years back that kept burning the deck drive belt. the problem was the paint on the pulley hadn't all com off and was create a rough spot when the deck wasn't engaged and would toast the belt in about 2 minutes so replace or smooth any rough pulleys because that could be the problem.
reddragon
look at the link i gave you and check out the single pto set up...make sure its routed properly....somrthing shredding your belts...look for any metal touching them in all positions...[blade engaged and deck lowered and vice versa]
reddragon
a picture of the damaged belt and mower would really help.....this is way too extreme..something is being missed!:rolleyes:
