Blowing the grass off of the mower and deck after every use is very good advice. Having a second set of blades isn't a horrible idea, but the op isn't a lawn care proffessional. Take the blades off after you have mowed your lawn 4 or 5 times and sharpen them before mowing again and you should be fine. Try to avoid running over gravel and tree limbs and the blades will last much longer. I have over 100 hours on the set on my mower and they are still in good condition.
Yes he can get by with only one set of blades but what happens is you don't quite have enough time to sharpen the blades so you do a quick cut not ( that takes 10 minutes longer ) and promise yourself you will do it next time when you are not in such a hurry, but that never happens, However having that presharpened blades sitting on the wall means you know it will only take 6 miutes to do so you do it.
Motorcycle chains are very similar story, have a clean one ready to change and you do it , pulling it off cleaning and greasing it before you go out into the spring sun, just never happens , till it is too late.
