125 miles from me. Might be worth the trip
Its gone now... did you drive fast?
It cuts great. I changed the oil a couple of times and it pretty much stopped smoking. Somebody had turned it up wrong way and got oil all in places it shouldn't be. Also think the guy left it outside and got some water in the oil.That's a nice machine and that's a good engine![]()
I know where to get one of those Suzuki Toros... but I have to buy a bunch of other stuff with it.Everyone wants the Suzuki 2stroke.... Nog everyone gets it. Yes that's a briggs gts I think its an older quantum engine. Carb probably needs cleaned,new plug, oil, air filter. Check valve adjustments. It run like new forever if you take care of it. As for the trans start with the cable. See if its adjustable if so try to adjust it, then check belt might be worn. Still having issues check drive gears on axle and wheels see if they are worn still have issues crack it open check for metal shavings and obvious damage repack with grease. That deck is a good one and the engine has plenty of powerthe weak spot on those mowers are the trans
Can't get 'em all. 12 in one day? I was thinking you worked alone.No it was just a little to far.
And trying to get 12 yards done today
I don't know if it qualifies as a deal but I picked up a John Deere SST16 Sunday. The hood is missing but that seems to be the way a lot of SSTs are. Must have been a fragile part. Works perfectly as far as I can tell. I'm going to take a close look at everything when the weather clears up. Not sure what I'm going to do with it :confused2: I mowed my friends front yard with it when I got it off the truck. I will not be putting it on the truck again. Getting it off the truck was a pain. Getting it on the truck when I bought it was a pain. No pics yet... been raining and cold since I mowed that yard. Paid 400.
I am not a JD fan so there is no such thing as a good deal on a JD.
$400 for a mower that runs and cuts grass without needing any work is a good deal.
John Deere is a good mower to make money on if you don't have to buy parts for it.
80% restored
Has the. Original briggs 16 hp twin side shaft.
Maybe a good deal for the right person.
What do you think he is asking for it?
