JonnyBlaze
- May 6, 2017
- 57
- 338
D170. 240 hours. Just purchased used. I noticed the tractor doesnt stop when I am on a hill when I let off the forward/reverse control. It stops with the brake pedal no problem. Also, with the trans disengage rod on the back, I can push the tractor forward and back with a little drag felt and moves freely without any drag with the rod pulled out, disengaged.
So is there an adjustment or does the drive belt need to be replaced or is this how the newer tractors operate?
