Yes. There were champions in themIs the engine turning over fast enough?
Also, what spark plugs did you use?
Ita a Briggs & StrattonIf you would post all model and serial numbers from the engine we would be better able to help you out.Its a briggs & Stratt
I have ordered a new solenoid. I am not hearing the click. I will try the carb cleaner thru the air intake and let you know.Take the spark plug out and pu a small amount of fuel ( I use carb cleaner ) down the hole replace the plug & crank
Engine fires = ignition timing is good & plugs working
Do the same down the carb throat
Engine fires a few times = valves are also working
That leaves fuel as the problem
Remove the solenoid in the carb & check that it retracts when the key is in the on position.
Let us know how it goes & don't forget to answer Rivets questions above at the same time .
Apologies. I hope this is what you are looking forThose are not the model, type or code numbers we need. They should be stamped on the shroud, above the plug or on the side.
