Snee Oosh1
John Deere D110 2013 mower. If I take the spark plug out it turns over fast, but oil sprays out. If I put the plug back in, it will not turn over.
Thanks. I will check that out.Usual cause is carb float not shutting off the fuel which ends up in the sump over filling the sump & thinning the oil
