land_owner
My 110 has a fixed (welded) bracket, factory sealed ends on the cable, and no way - other than to cut and reform - the tensioning spring. There is no adjustment for which I can readily see. The new 42" belt was installed in the manner in which the packaging on the belt indicates. The belt continually falls off - as did the former belt, which was changed to prevent this.
Is 42" the right length belt? How do I tension in this case?
