biodiesel
That has been cracked for a very long time
Failure to properly grease the spindle eventually cause the bearing to collapse and the balls hammering around inside finished the job.
So quite some time back it coped a big bang but kept on running till it ultimately failed .
I've read some conflicting information so maybe you can clarify. I've heard that greasing the spindles doesn't help since the bearings are sealed. Is this true? The directions say to grease the new spindles, so maybe some are sealed, and some aren't?
