sgkent
I did it for a living in a machine shop many years ago, learning that trade from a master who built engines and racing cars for the Unser family and others. Also street cars, classic cars, fleet cars, motorcyles etc.. Generally the bore is sized to the individual piston. It is not cost effective for a small engine when engines from China that are Honda clones aren't all that expensive. But there are shops that do it if you want it done. Call me an idiot but I would rather restore an engine to like new than buy a new one. Not always. I cannot get what I want new normally unless I do it blindly, and so many times what you get is not what was advertised. That said, time is worth a minimum of $100 an hour in any trade these days, plus materials, and it is about a one hour process to get it right. Whether it is bored then honed, or just honed, the final process is a rough stone is used then a finishing stone the last little bit. Moly rings take a special finish. For a lawn mower, if the cylinder has normal wear, a bottle brush finish is 2 minutes unless you know someone with a Sunnen hone who owes you a favor. That said, if you need to bore it oversize, the valve guides, and maybe valve seats are gone too so better know someone who does them. Typically a go-cart racer will know people who do these things.
James Condon built an engine recently that the bore was too corroded to use so a subscriber named Ron on his channel with a Sunnen hone offered to bore it .020" over for him. He showed a few seconds of the process on the sunnen hone, but I just looked thru that video a dozen times and can't find the segment so maybe he edited it out. I looked up auctions in case anyone wants to DIY, and a recent sale of a CK10 sunnen hone was $7800. That is 50 year old (and 3-phase) technology but precise. You can buy a lot of lawnmower engines for $8000. In Condon's situation, the engine was a almost zero hour engine that someone had not used so moisture had destroyed the cylinder. We saw a video today of an almost zero hour Cessna 182T that had been sitting in a hanger for 14 years in Idaho, but the moisture in the air had just destroyed the inside of the cylinders. Cost them a small fortune to have it rebuilt.
