skipper124
I have a 2007 Yardman MTD that cuts bad on one side. I noticed when I replaced the blades one of the star spindels was almost worn completely down. Would this cause it? Also can you get a part for that?
you are better off just replacing the whole spindle and do both13AC762F755
hard to say, might have just rusted that way or you could have hit something and never noticed the damage when you changed the bladePretty sure it was always seated properly. Nuts coming loose I'm not sure. I do remember about 5 years ago the deck was shaking violently and I didn't know why. I finally found out the belt had a chunk out of it. I replaced it with a new one. Would this have caused it? Also would the belt be worn out already and slipping as a possible cause?
