cub cadet
jhb55
i have a cub cadet 50 inch cut. i think im having some kind of a electrical issue. my volt meter screen will come on when starting and it starts then it will die when the motor starts to die the volt meter screen goes off. it does this every time you start it. could it be the ignition switch?
All seems good. It will stay running as long as i hold the key in the start position. As soon a i let it go to run position it will die.
Good one! This has been a long time since I work on one. LOL. The rear trany pulley was aluminum and the belt would wear the V pulley wide, then the belt would ride down to the bottom and then slip.
Back to your electrical. This has happen to me before many times, but not on this model. The thing that comes to mind is the key switch, but I don't think that's it, but look at the back where the wires plug into it. Look for burn thru at black plug.
Next would be one of the two relays. They are in a bad place to get too. Remove the battery and you will see them, one up and one down. I can't tell you witch one may be bad. I know one is for the PTO, the other I can't remember what it did.
What maybe happing is your bypassing something as long as you hold the key to start. Then let go and lose your spark....... .. ... .. .. . I'm still thinking.
