cub cadet SLT1554
cub6791
got a sv740 kohler engine and want to bypass the speed advance module because the engine won't start or if someone has wiring diagram of the module color code thanks
Post the spec number from the engine model number tag. Some of those engines have a SAM to MDI ignition conversion kit available. You get two new modules, and some wire fittings to adapt to the old wiring harness, and then you can throw the SAM away.
cub6791
sv740 spec ps-sv740-0010 serial 3606925763 Dom 3/10/2006
Looks like the kit that you need is the 32 707 01-s DSAI to MDI module kit. Looks like the kit is $102.
