R ronaldcolla Forum Newbie Apr 29, 2017 #1 I have a cadet push mower not 2 years old wouldn't start cleaned out gas tank , blew out fuel line , replaced carb with brand new one won't stay running with out spraying carb cleaner into carb or it will die out ant ideas
BlazNT Lawn Pro May 4, 2017 #2 You did this backwards and go crud back in a new carb. You should clean gas tank then replace fuels lines and filters then clean or replace the carb.
